Neuron Posted March 6, 2012 Share Posted March 6, 2012 Hi, I don't have another car to jump start my dead battery of my 2004 Honda Accord. However, my husband has a motorcycle. Would it be possible to use the motorcycle's battery to jump start my car without damaging the motorcycle? Also, I'm thinking of buying a battery booster. Any ideas as to what type I should buy? Thank you for your help in advance. Link to comment Share on other sites More sharing options...
Turtlehead Posted March 6, 2012 Share Posted March 6, 2012 Yes you can jump start off the bike if it has a 12v system as it probably does. The crank amp's will be higher for your car than the bike so connect the cables and let the bike run gor a while with the car off to charge to battery, and then (with the bike battery still connected) start the car. You should not need a booster for the car. You might have a P-static drawdown on the battery, thus there could be an electrical issue in the car, OR the battery is simply bad. I recommend either and ACDeloc 7 year or a Honda battery if that is the case. Link to comment Share on other sites More sharing options...
Neuron Posted March 6, 2012 Author Share Posted March 6, 2012 Thanks so much Turtlehead. I'll do as you instructed. After recharging the battery, I plan to take my car in for service to get it checked out. Link to comment Share on other sites More sharing options...
1Bobbychet! Posted March 15, 2012 Share Posted March 15, 2012 Plus don't tell your Husband that you used his bike to jump your car lol Bobbychet Link to comment Share on other sites More sharing options...
