Deejayphilo Posted March 13, 2012 Share Posted March 13, 2012 I swap my blown engine with same F22. It crank freely when I put the timing belt but after I mate with the tranny I can't crank it manually anymore. Is it suppose to be like that...? Link to comment Share on other sites More sharing options...
Raley Posted March 13, 2012 Share Posted March 13, 2012 Is it on the ground, in gear, clutch pressed? Link to comment Share on other sites More sharing options...
Turtlehead Posted March 13, 2012 Share Posted March 13, 2012 I swap my blown engine with same F22. It crank freely when I put the timing belt but after I mate with the tranny I can't crank it manually anymore. Is it suppose to be like that...? You need to state if it is a manual transmission or not, plus the year... If you need a direct answer then it would be NO assuming it is off the ground. Link to comment Share on other sites More sharing options...
