tmcamp626 Posted March 22, 2012 Share Posted March 22, 2012 I haven't gotten any replies to my other topic, but this is a different one, so I'm asking: Why does the CEL only come on when my daughter's 94 Honda Accord EX is at 1/4 tank of gas or lower? I accidentally reset the CEL when I pulled the backup (radio) fuse the other day, looking for a reason the radio didn't work (found it with the lighter fuse), so any stored codes were gone when I took it to work to have the codes read and Advanced Auto doesn't have a scanner to read OBD1. Any suggestions as to what could cause the CEL to come on at this level? Thanks! Link to comment Share on other sites More sharing options...
Raley Posted March 22, 2012 Share Posted March 22, 2012 ummm... im not an accord guy but all i can think of is that its not sucking enough fuel so its trying to run lean, but that would be very unlikely... Link to comment Share on other sites More sharing options...
Xeryon Posted March 22, 2012 Share Posted March 22, 2012 Seems like a silly question, but do you have the fuel cap on? If so there might be a leak in the fuel fill tube. The Accords will generate a CEL when gas fume concentration isn't high enough. It is part of the LEV and ULEV certifications they had. When the tank is full there may be enough evap it isn't setting off the sensor. Link to comment Share on other sites More sharing options...
