EZNACHO Posted April 16, 2012 Share Posted April 16, 2012 Hello, my name is Edson I've looked around in the forums and haven't quite been able to find the answer I've been looking for. I have a 96 Accord Station Wagon ABS AUTOMATIC 2.2 VTEC I had a problem with the brakes going straight in after slowly stopping to function to correctly. First, I started by bleeding the brakes, that worked but eventually the same thing started happening after about 3 weeks. Second, I replaced the master cylinder, that too also fixed it for about 3 weeks and the problem happened again. Third, thinking it was a buggy master cylinder I replaced it again and now the same thing is happening after about 3 weeks. I need some help I'm not sure if it's the brake booster or the ABS (note: the abs reservoir has been empty for like the last 3 years I read something about that online). From what I can see there is no leak and the BRAKE RESERVOIR is full. Link to comment Share on other sites More sharing options...
Raley Posted April 17, 2012 Share Posted April 17, 2012 your check valve to the booster might be bad... id have to guess its leaking somewhere though. Link to comment Share on other sites More sharing options...
