imcomininhot Posted April 21, 2012 Share Posted April 21, 2012 what's up peoples - na, hey been a honda fan for a long time. mechanic told me that this accord is nothing like my civic's I've had in the past. 93 accord, 4 door, 5 spd, engine pretty much stock. Mech' said that if I change the timing belt, (like I did a couple other times on my civics) that I'd also have to remove the oilpan, remove 4 bolts from the oil pick up unit and change its gasket, otherwise it's likely to leak, after a timing belt job. I'm calling bluff on that dude - there was a language barrier, so I felt like he was saying that it would ruin your timing belt job. he was trying to get me to have him do it, parts and labor $775 + tax... I'm trippin' on that, but he's got me a bit concerned with anything in addition that needs to be done. I'm used to it only taking me about 3 hours on the d16, non vtec. So, is there an additional gasket that I "have to" change during a timing belt job Link to comment Share on other sites More sharing options...
Raley Posted April 22, 2012 Share Posted April 22, 2012 nothing is a "have to" but its recommended to do a water pump and gasket... Link to comment Share on other sites More sharing options...
imcomininhot Posted April 24, 2012 Author Share Posted April 24, 2012 Thanks for the post Raley - Just to update, I've researched a bit. the oil pump runs at the bottom directly off the crank pulley - that's what the Mech was saying, if it goes bad itself, then the timing belt job will need to be done all over again, cuz it sits behind the timing belt job... if I was going to pull the pump off to replace the gasket, I'd just replace the whole dam pump. does anyone "always" change that oil pump on a timing belt job? water pump, I understand, and it's expected, however oil pump? Link to comment Share on other sites More sharing options...
Raley Posted April 25, 2012 Share Posted April 25, 2012 i personally have not, but in the same mindset, probably should have, its not really that expensive to KNOW its good for another 60k... Link to comment Share on other sites More sharing options...
Xeryon Posted April 26, 2012 Share Posted April 26, 2012 I've never changed the oil pump or the gasket. Never had one leak or go bad either. To each their own I guess. As for $775 being the price of a timing belt, water pump, accessory belts, oil pump and oil pump gasket I would say that isn't a terrible price. He isn't doing you a huge favor or anything. I had a professional friend do the TB, WP and belts on my 98 Accord at his shop and he charged me $500, which was reasonable. Link to comment Share on other sites More sharing options...
nvrgtgnjdgd Posted May 29, 2012 Share Posted May 29, 2012 Thanks for the post Raley - Longchamp Outlet Tiffany & Co Outlet Karen Millen Outlet Abercrombie & Fitch Wholesale Just to update, I've researched a bit. the oil pump runs at the bottom directly off the crank pulley Link to comment Share on other sites More sharing options...
Raley Posted May 30, 2012 Share Posted May 30, 2012 then gimme a plus 1, come on bot, i need your support!!! Link to comment Share on other sites More sharing options...
