phorton951 Posted June 4, 2012 Share Posted June 4, 2012 I have a 1984 accord and the head/tail lights won't work.when turned on at the switch , my high beams, turn signals and brake light all work, i have heard it is most likely the switch and am getting no power on either side of the fuses, any way to verify if its the switch or not ? Link to comment Share on other sites More sharing options...
Xeryon Posted June 5, 2012 Share Posted June 5, 2012 disconnect the wires on the back of the switch and touch them together directly. Link to comment Share on other sites More sharing options...
phorton951 Posted June 5, 2012 Author Share Posted June 5, 2012 Thank you, I pulled the switch out and found the light switch itself was broken so turning the headlight switch on it wasnt connected to anything, is there a place that I can get an internal light switch diagram showing the moving parts so i know exactly what to replace, the replacement combo switchs run from 90-200 so im trying to avoid spending that much if its not needed, thanks Link to comment Share on other sites More sharing options...
Xeryon Posted June 5, 2012 Share Posted June 5, 2012 Thumb through a chiltons or haynes manual. Alternatively, have you priced eBay or any local salvage yards? Link to comment Share on other sites More sharing options...
Raley Posted June 5, 2012 Share Posted June 5, 2012 POSSIBLE hondaautomotiveparts.com will have something. Link to comment Share on other sites More sharing options...
