paul7475 Posted July 8, 2012 Share Posted July 8, 2012 I have an 06 accord ex 4 cyl with warped front rotors. No crazy driving either. What to replace them with, both rotors and pads. Nothing high perf. Looking for quiet, reliable and won't warp. The same thing happened to my 2000 accord but I sold it. Paul Link to comment Share on other sites More sharing options...
airjordan223 Posted July 8, 2012 Share Posted July 8, 2012 http://www.autopartswarehouse.com/search/?N=0&Nr=AND(wpn_tl_name:Brakes%5C%2C+Suspension+%26+Steering,wpn_cat_name:Brake+Discs%5C%2C+Pads+%26+Calipers,wpn_scat_name:Brake+Discs+%26+Components,part:Brake+Disc) Link to comment Share on other sites More sharing options...
paul7475 Posted July 9, 2012 Author Share Posted July 9, 2012 airjordan223 There are a lot of choices here. Are you recommending the ECB brand and if so does it matter which ones? Link to comment Share on other sites More sharing options...
James Matteu Posted July 9, 2012 Share Posted July 9, 2012 After running through several brands, all of which failed to keep from warping under the weight of my V6 (3900#), I finally came to buying Brembo Blanks. Best OE spec rotors hands down. Anything better is going to be slotted or cross-drilled. Link to comment Share on other sites More sharing options...
airjordan223 Posted July 9, 2012 Share Posted July 9, 2012 ^Spot on as usual. Link to comment Share on other sites More sharing options...
