James Matteu Posted October 15, 2012 Share Posted October 15, 2012 http://static.photobucket.com/player.swf?file=http://vid268.photobucket.com/albums/jj7/Js2d355jf69lsd/VIDEO0039.mp4 Plan A: Re-use damaged motor mount bracket. Keysert, Helicoilc, or Timesert? My attempt to drill out the holes in preparation to be threaded for the Helicoil didn't go as smoothly as I hoped. I wanted to work with the bracket on the car since two of bracket's fasteners sit beneath the intake manifold. That decision restricted my room to work and ultimately lead to a bad angle for the drill. Once the bit sagged the side of the hole I realized the angle was bad and that the bit I bought wasn't the right one for the job. I figured the hole was smooth enough from banging around the motor mount bolt so drilling wouldn't be completely necessary. I figured I could just tap the hole and move on with putting in the insert. I figured wrong. Plan B: cant get the bracket of an engine at a junkyard? if not just step it up to the next size Yes. I looked online last night and found three 1st Gen Acura Legends at Ace Pick-A-Part. I know I'm desperate when I'm willing to go to Ace' date=' they're expensive and have the worst, nastiest customer service. I expect to pay close to $50 for the bracket. I cannot make my way out there until Thursday and cannot reinstall the motor mount with the broken tap stuck in the hole. I figured the mount hadn't been attached, so I must've not been holding the motor steady. That last statement proved to be another bad assumption. This morning and last night, I could hear the Power Steering Pump Pulley rubbing on the $108.00 A/C Suction Line (hardline). The last thing I want right now is to break something else. I need to remove the PS Pump until Thursday or Friday. I'll be removing it today after work. [b']Question: Can I remove the pump and leave the lines open to atmospheric pressure? I'm not too concerned with a little hydraulic fluid as I can bag the lines. Or, do have to loop the high and low sides?[/b] Plan C: Buy new bracket from Honda: $250.00 USD. Even more disturbing is a noise that popped up last winter that would come and go. I had been searching for it when I found the bad bracket and motor mount; I was convinced this was the source of the noise. Now the bracket isn't even attached to anything and the mount not even on the car: the noise is still present. I plan on leaving the A/C Belt off for a day to see if I can make the noise go away like that; I have a suspicion its coming from a bad Pulley Bearing. Thing is, it doesn't sound like any bad bearing I've heard before. Link to comment Share on other sites More sharing options...
Xeryon Posted October 17, 2012 Share Posted October 17, 2012 When was the last time you had the distributor cap off? I have seen more than one distributor bearing grind itself to dust. BTW, you get yourself into the most ridiculous messes. Link to comment Share on other sites More sharing options...
James Matteu Posted October 17, 2012 Author Share Posted October 17, 2012 Well, so far this noise appears to be a composite of several things, which to me explains why I would choose to describe it as disturbing. The grinding: bad bearingsin the A/C Compressor. I don't know yet if this is the internal bearingsor theClutch/Pulley bearings. I'm banking on the latter. The vibration: the bad, now missing, motor mount. The tapping:thevalves The deep grumbling on acceleration: the hole in the intake tube (repaired last night). Today, I'll adjust valves after work (exhaust) so I can get a better idea of how many dirty hydraulic tappets (C27A4) there are by using my stethescope. But, I have an o-ring for the distributor I've been meaning to change so I'll do that today and check the bearing while I have it off. Link to comment Share on other sites More sharing options...
