Will Frank Posted March 15, 2013 Share Posted March 15, 2013 Okay, so I changed the heater core and had to take the dash apart. Before I changed it the windshield washers worked, now they don't. I don't know where i messed up! Link to comment Share on other sites More sharing options...
Jeff Collision Posted March 15, 2013 Share Posted March 15, 2013 Turn on the windshield washer with the engine off and the key in the On position. Listen for a humming sound to determine whether the windshield washer motor is operative. Open the hood and listen while you turn on the windshield washer. If you don't hear any sound, check the fuses. Replace the fuse if it is blown. If the fuse is not blown and the motor is silent, have your mechanic replace the windshield-washer motor. Check the reservoir and add windshield-washer fluid if its level is low or empty. Link to comment Share on other sites More sharing options...
