javelinman74 Posted March 17, 2013 Share Posted March 17, 2013 Wife's Accord heater fan stopped the other day. Checked out the fuse under dash and the fuse in engine compartment. Both are good. I did jump the engine compartment contacts to be sure and nothing. So figuring the heater motor must be bad. How difficult is access and replacement on the Honda? Appreciate any help and or direction. Richard Link to comment Share on other sites More sharing options...
James Matteu Posted March 18, 2013 Share Posted March 18, 2013 That year Accord is more difficult than the 94+ models but it's not like you'll be taking the dash out, just removing the blower assembly: the black box behind the dglove box. When you have it unbolted and partly out you might snag a wire. Feel behind it with your hand to be sure you didn't snag a wire, there's a few wires behind it that can get snagged. Look around online, there's lots of info on removing these. Link to comment Share on other sites More sharing options...
Cuba Rodriguez Posted April 30, 2013 Share Posted April 30, 2013 you could also unplug motor connector usually accessible under hood, and feed 12v to see if it activates... sometimes along harness, wires can burn or break or corrode or mice chew...also check resistor which is a common culprit..... just a thought before replacing Link to comment Share on other sites More sharing options...
