BigWink1980 Posted March 25, 2013 Share Posted March 25, 2013 Hey i have a 1996 Accord and the shifter wont move out of park without me putting the key the in shift lock key hole on the console and my trans only works correctly if i manually shift the gears and its an automatic...any solutions on how i can fix these problems.. Link to comment Share on other sites More sharing options...
Cuba Rodriguez Posted April 30, 2013 Share Posted April 30, 2013 actually if the brake light switch on the pedal is not working, it will also cause the same symptoms as far as not being able to get out of park.... check to see if brake lights work when applying pedal. Keep It Simple... check fuses too, sometimes things get sticky in shifter from spills.... as far as manually having to shift, that does sound internal...double check fluid level though anyway (with car running idle and in park) already warmed up from driving.... but give it time enough to settle back down dipstick keep us updated and good luck! Link to comment Share on other sites More sharing options...
