tonyp Posted April 6, 2013 Share Posted April 6, 2013 Hello, I have a 1992 honda ex, when stationary I get a single "clunk" when I turn the wheel to the right, not left. When I put it up on jack stands and turn the wheel there is no noise, no "clunks". Any ideas? Thanks Link to comment Share on other sites More sharing options...
James Matteu Posted April 6, 2013 Share Posted April 6, 2013 Lug nuts. Link to comment Share on other sites More sharing options...
Jeff Collision Posted April 17, 2013 Share Posted April 17, 2013 Its either a sway bar or a stabilizer bar. At each end of this part, there is a small link that attaches the bar to the lower control arm. These end links are the parts you may need to replace, or they could either be loose or just binding. Link to comment Share on other sites More sharing options...
Cuba Rodriguez Posted April 29, 2013 Share Posted April 29, 2013 I would check all suspension and steering parts.... ball joints, tie rods, stablizer bar linkages, control arm bushings, struts and their mounts, etc..... shake, shimmy, and touch all parts by hand... look for dry rotting or tearing rubber on bushings.... keep us updated and good luck! Link to comment Share on other sites More sharing options...
