Whamilton76 Posted January 14, 2016 Share Posted January 14, 2016 Recently the right side low beam headlamp went out on my 2005 Accord EX. Thinking that a burnt out bulb was the issue, I changed it. This didn't fix the problem. I checked the fuse and it looked solid. There was no break in it at all. To make sure that the fuse was good I switched it over to the left headlamp fuse slot. Both the high and low beams came one. The fuse was fine. When I put the old bulb back in I twisted the socket back in place and the light came on! After driving around for a day the light went out again. I spoke to a friend about this and he told me that the connector had gone bad. So I went to Autozone and picked up a 9006 headlamp socket. I wired the new one in but no luck that didn't fix the problem either. The high beam is functioning right so I'm pretty positive that I got the wiring correct. So what's the issue? At this point I'm assuming that I'm looking at an internal wiring issue. I'm hoping that's not the case but I don't know what else it could be. Any help here would be awesome! Link to comment Share on other sites More sharing options...
Sam01 Posted January 15, 2016 Share Posted January 15, 2016 I also think this is because of wiring issue. If you will go to workshop they will charge around 50$ -60 $.You can easily solve your problem through repair manual. Download the pdf file from http://www.reliable-store.com/pages/search-results?q=2005%20accord%20ex&p=2and resolve your problem Link to comment Share on other sites More sharing options...
Humphries Posted January 16, 2016 Share Posted January 16, 2016 the pigtail has a bad connection at the headlight. replace pigtail Link to comment Share on other sites More sharing options...
