outside mirror led turning signal
jasonrayjohnson1970
I have an issue with my 2020 Honda Accord EX and wanted to see if anyone has an answer before I take it to the dealership. Everything with my outside mirrors work as they should but the led turning signals. The power mirror adjusts fine, the heated part works fine, and the blind spot monitor works fine but the led turning signal doesn't. The turning signals on the car work fine also. Is there a certain fuse or relay that controls these? I actually ordered a set off of Amazon to see if maybe the led part just didn't work but when I plugged in one to test it the led turning signal still wouldn't work. HELP!
  • 8 months later...
