Toddy Posted February 3, 2004 Share Posted February 3, 2004 where should i run my wires in my 91 Accord? (RCAs Remote and power wires?) Link to comment Share on other sites More sharing options...
TLontheDL Posted February 5, 2004 Share Posted February 5, 2004 how about the area beneath your shift plate? then under the passenger seat, to the door sills, and then run it along the sills to the trunk? Link to comment Share on other sites More sharing options...
Toddy Posted February 6, 2004 Author Share Posted February 6, 2004 thast what i did thanks for the reply Link to comment Share on other sites More sharing options...
luchesse Posted July 9, 2008 Share Posted July 9, 2008 thast what i did thanks for the reply Howd you run the wires through the firewall? Link to comment Share on other sites More sharing options...
TLontheDL Posted July 15, 2008 Share Posted July 15, 2008 There is a rubber seal that the factory has in the engine bay. Wires are already running through it so you can run the wires through there. Link to comment Share on other sites More sharing options...
James Matteu Posted July 15, 2008 Share Posted July 15, 2008 thast what i did thanks for the replyHowd you run the wires through the firewall? There is a rubber seal that the factory has in the engine bay. Wires are already running through it so you can run the wires through there. My technique is to take a PaperMate pen, cut the back of it off, and remove the ink barrel. This leaves me with a hard plastic tube that is just the right size to shove through the rubber seal that is in the firewall. I then pass the wire through the pen tube, then pull out the pen tube which leaves the wire behind inside the rubber seal. Link to comment Share on other sites More sharing options...
Kastigir Posted July 15, 2008 Share Posted July 15, 2008 My technique is to take a PaperMate pen, cut the back of it off, and remove the ink barrel. This leaves me with a hard plastic tube that is just the right size to shove through the rubber seal that is in the firewall. I then pass the wire through the pen tube, then pull out the pen tube which leaves the wire behind inside the rubber seal. This. Link to comment Share on other sites More sharing options...
luchesse Posted July 16, 2008 Share Posted July 16, 2008 There is a rubber seal that the factory has in the engine bay. Wires are already running through it so you can run the wires through there. I can't seem to et the wires through since the fuel thing is back there, any suggestions? Link to comment Share on other sites More sharing options...
